Sony Xperia 10
Solution 4 of 4: Your phone hasn't been correctly set up for POP3 email
You can set up your phone to send and receive email messages from your email accounts. To set up your phone for POP3 email, you need to set up your phone for internet.
Press Accounts.
Press Add account.
Press Email.
Press Email address and key in your email address.
Press NEXT.
Press NEXT.
Press POP3.
Press the field below "POP3 server" and key in the name of your email provider's incoming server.
Press the field below "Port" and key in 110.
Press None to turn off the function.
Press the drop down list below "Delete email from server".
Press Never to keep email on the server when you delete them on your phone.
Press When I delete from Inbox to delete email on the server when you delete them on your phone.
Press NEXT.
Press the indicator next to "Require sign-in." to turn on the function.
Press NEXT.
Press SHOW MORE SYNC OPTIONS.
Press the drop down list below "Automatically".
Press the required setting.
To turn on manual retrieval of email messages, press Manually.
Press Sync email to turn on the function.
Press NEXT.
Press NEXT.
Press the field below "Set account name (optional)" and key in the required name.
Press the field below "Your name (shown on outgoing messages)" and key in the required sender name.
Press FINISH SETUP.
