Sony
Xperia 10 IV
Sony Xperia 10 IV
f-3add1000-95e7-431a-8a8d-efcb3497629c
f-02aeae67-0dd6-466e-a990-911604380276
f-f0950ec4-5a14-47cc-9927-303b5e37a159
f-5ad8b63c-fa0a-4f26-8007-97dd762a3779
f-17905777-9542-4547-90e6-56d51d086911
f-c828999f-52f5-4f4d-b76e-381c910ef980
Can you make a voice call?
