Sony Xperia 10 IV
Solution 15 of 15: GPS is turned on
Press Location.
Press the indicator next to "Use location" to turn the function on or off.
Press App-level permissions.
Press the required app.
Press the required setting.
Press the Return key twice.
Press Location Services.
Press Google Location Accuracy.
Press the indicator next to "Improve Location Accuracy" to turn on the function. If you turn on the function, your phone can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
Press the indicator next to "Improve Location Accuracy" to turn off the function. If you turn off the function, your phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
