Sony Xperia 10 VI
Solution 2 of 3: GPS position usage for applications is turned on
Press Location.
Press the indicator next to "Use location" to turn the function on or off.
Press App-level permissions.
Press the required app.
Press the Return key twice.
Press Location Services.
Press Google Location Accuracy.
