Sony
Xperia 5
Sony Xperia 5
f-6e7fc3a0-5f77-4f7a-81b8-aedff282547b
f-057eee47-c0a4-4b64-b449-470fba184fc5
f-0123d944-126c-45f8-9735-99ed5f9a5f8e
f-8a08752f-3fff-4e1d-8064-e1713d3b88a5
f-b36798b2-f4ee-4373-9693-fe3dacf3aca3
f-37cc6c75-affb-4a77-8384-fb0c2a91506a
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
