Sony Xperia 5 ii
Using music player
You can use the music player to play audio files you have transferred to your phone.
Press Music.
Press the required category and go to the required audio file.
Press the required audio file.
Press the upper or lower part of the Volume key to adjust the volume.
Press the song title at the bottom of the screen.
Press arrow right to go to the next audio file.
Press arrow left twice to go to the previous audio file.
Press the shuffle icon to turn the function on or off.
Press the repeat icon to turn the function on or off.
Press the add icon.
Press Create new playlist.
Key in a name for the playlist and press OK.
