Sony
Xperia 5 ii
Sony Xperia 5 ii
f-08873c36-86d7-4838-910b-57f8b79ddbec
f-919854f4-2145-4276-8d0b-69d9e6823bb8
f-35e77070-1548-4f30-bdd3-2d9f50c56979
f-76e04f16-32a3-4a3c-99dd-bb0f8f83b940
f-a309864c-43a0-46b4-9c83-87ce0c21cb3d
f-154d0868-ad42-48a5-b64a-628084c9e202
Can you use Wi-Fi?
