Sony
Xperia 5 ii
Sony Xperia 5 ii
f-08873c36-86d7-4838-910b-57f8b79ddbec
f-919854f4-2145-4276-8d0b-69d9e6823bb8
f-35e77070-1548-4f30-bdd3-2d9f50c56979
f-76e04f16-32a3-4a3c-99dd-bb0f8f83b940
f-a309864c-43a0-46b4-9c83-87ce0c21cb3d
f-154d0868-ad42-48a5-b64a-628084c9e202
Solution 1 of 3: GPS position usage for applications is turned on
Step 1 of 13
Step 2 of 13
Press Location.
Press Location.
Step 3 of 13
Press Location.
Step 4 of 13
Press the indicator next to "Use location" to turn the function on or off.
Press App-level permissions.
Step 5 of 13
Press the required app.
Step 6 of 13
Press the required setting.
Step 7 of 13
Press the Return key twice.
Step 8 of 13
Press Advanced.
Press Advanced.
Step 9 of 13
Press Advanced.
Press Google Location Accuracy.
Step 10 of 13
Step 11 of 13
Press the indicator next to "Improve Location Accuracy" to turn on the function. If you turn on the function, your phone can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
Step 12 of 13
Press the indicator next to "Improve Location Accuracy" to turn off the function. If you turn off the function, your phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
Step 13 of 13
