Sony Xperia 5 ii
Solution 3 of 3: Your phone doesn't turn on correctly
Before you can turn on your phone, you need to insert your SIM and battery into your phone.
If you're asked to key in your PIN, do so and press arrow right. The default PIN is 1111.
Press and hold On/Off.
Press Power.
Press Power off.
