Sony Xperia 5 iii
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Network and Internet.
Press Hotspot and tethering.
Press Portable hotspot.
Press Hotspot name and key in the required name for the Wi-Fi hotspot.
Press OK.
Press Security.
Press WPA3-Personal to password protect your Wi-Fi hotspot.
Press Hotspot password and key in the required password.
Press OK.
Press the indicator below "Portable hotspot" to turn on the function.
