Sony
Xperia XZ3
Sony Xperia XZ3
f-297bf30a-6834-4026-be8d-cf232e7fa532
f-ae668bc1-94db-49cc-b162-47137e44d2aa
f-d1ee3d2a-a79c-41bd-9993-4cbb3cb71e78
f-39522136-f1a6-4b4f-b512-b7eec49f70d7
f-5b6c52b5-a401-4140-95f0-d5e8bb8e4be5
f-9a9e96b2-97b3-4610-b4f0-9a06c4a8a728
Can you make a voice call?
