TCL 10 Pro
It's not possible to receive messages on my voicemail
Solution 3 of 3: Incoming calls aren't diverted to your voicemail
Press the phone icon.
Press Calling accounts.
Press the name of the SIM.
Press Call forwarding.
If you divert missed calls, you need to select a delay for the divert. Press the drop down list and follow the instructions on the screen to select a delay for the divert.
Key in +447953222222 and press ENABLE.
