TCL
40R 5G
TCL 40R 5G
f-371a88da-055e-4bba-9f11-5205a250414c
f-df655d03-b7c4-416d-b1fd-9c1a78fa77bc
f-3691e735-d216-4b74-8e54-a0b677d6cb14
f-3db7f721-03a4-465c-b6f2-f4cfa6659297
f-40c4894d-6c4e-4957-a830-c3414fd3f4d2
f-f1eab9d9-9ad9-4bde-8341-f9ec52249082
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sound & vibration.
Press Phone ringtone & vibrate.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press the Return key.
To use a different ring tone than the default ones, press Custom ringtone and follow the instructions on the screen to select the required ring tone.
