TCL
50 5G
TCL 50 5G
f-b6566bd3-e7fc-4fc8-9a5f-a75505894a77
f-6c4ee75e-46a3-4b66-a052-ad9fc936ffcc
f-85282573-4852-4ee1-b32f-d6340ebd4705
f-1973e2b8-a4ab-4364-8e1c-058b89634bb1
f-1f58e8e8-2ac4-4ce5-9185-c1396afa5272
f-b12207a3-cc3c-430b-93d1-c70b2db5247e
f-4680b6ca-1b8c-4a6f-b104-feaab6ec69e6
f-9b540082-6466-4f29-ad29-682415659b5e
Step 1 of 33
Step 2 of 33
Press Accounts.
Press Accounts.
Step 3 of 33
Press Accounts.
Press Add account.
Press Add account.
Step 4 of 33
Press Add account.
Press Personal (IMAP).
Step 5 of 33
Press the field below
Step 6 of 33
Press NEXT.
Press NEXT.
Step 7 of 33
Press NEXT.
Step 8 of 33
Press NEXT.
Press NEXT.
Step 9 of 33
Press NEXT.
Step 10 of 33
Step 11 of 33
Step 12 of 33
993
993
Step 13 of 33
Press the field below "Port" and key in 993.
Step 14 of 33
Press SSL/TLS.
Press SSL/TLS.
Step 15 of 33
Press SSL/TLS.
It's recommended that you turn on encryption of incoming email messages so that all email messages you receive are encrypted and secured in the best possible way.
Press NEXT.
Press NEXT.
Step 16 of 33
Press NEXT.
Step 17 of 33
Step 18 of 33
Step 19 of 33
Step 20 of 33
587
587
Step 21 of 33
Press the field below "Port" and key in 587.
If you're having problems sending email messages, try keying in 465 instead or ask your email provider for the correct outgoing port.
Step 22 of 33
Press SSL/TLS.
Press SSL/TLS.
Step 23 of 33
Press SSL/TLS.
It's recommended that you turn on encryption of outgoing email messages so that all email messages you send are encrypted and secured in the best possible way.
Press NEXT.
Press NEXT.
Step 24 of 33
Press NEXT.
Step 25 of 33
Press the required setting.
Step 26 of 33
Press the field next to
Step 27 of 33
Step 28 of 33
Press NEXT.
Press NEXT.
Step 29 of 33
Press NEXT.
Step 30 of 33
Step 31 of 33
Press the field below "Your name" and key in the required sender name.
Press NEXT.
Press NEXT.
Step 32 of 33
Press NEXT.
Step 33 of 33
