iPhone 11 Pro
iPhone 11 Pro
f-d58d818c-46b3-4cdd-aacf-cb56c2e5c3e9
f-df7b0086-ec80-45f9-9dea-129aa40c8c79
f-c1e36cc4-b186-4ca5-947c-fed1d64a3e28
f-609c85e1-4fc2-445d-8907-e59ce072dcd0
f-fb87405b-7a33-4ab5-a030-09ee613266b7
f-eb0f7e31-740b-4780-aa33-266686532943
Device home
Getting started
Basic functions
Calls, contacts, messaging
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
