iPhone 11 Pro Max
iPhone 11 Pro Max
f-3a7e4ec0-1475-4f61-a930-084fea643e88
f-5a24cf43-c92b-4747-b090-cb49cce6a42d
f-f13b3424-3ff9-4db3-81c3-18e0f3392f93
f-ba1a3150-61a5-4025-8a07-71094920c51f
f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f
f-a1614ec3-2011-49e3-9b5e-d8df99f321a8
You can transfer files, such as pictures or audio files, between your computer and your phone. Please note that the following steps are based on Windows OS which means the instructions do not correspond with other operating systems.
Step 1 of 12
Before you connect your phone and computer, you need to install iTunes on your computer.
Step 2 of 12
Click iTunes.
To transfer files from your computer to your phone, you need to add your files to the iTunes library.
Step 3 of 12
Click File.
Step 4 of 12
Click Add File to Library... to add one file at a time.
Step 5 of 12
Click Add Folder to Library... to add a folder.
Step 6 of 12
Go to the required file or folder in your computer's file system and follow the instructions on the screen to add a file or folder to the iTunes library.
Step 7 of 12
Depending on your settings in iTunes, the transfer may start automatically. To manually start the transfer, click the iPhone icon.
Step 8 of 12
Click the required category, and follow the instructions on the screen to select the required settings.
Step 9 of 12
Click Apply.
Step 10 of 12
Step 11 of 12
Go to the required folder in your phone's file system.
Step 12 of 12
