iPhone 11 Pro Max
iPhone 11 Pro Max
f-3a7e4ec0-1475-4f61-a930-084fea643e88
f-5a24cf43-c92b-4747-b090-cb49cce6a42d
f-f13b3424-3ff9-4db3-81c3-18e0f3392f93
f-ba1a3150-61a5-4025-8a07-71094920c51f
f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f
f-a1614ec3-2011-49e3-9b5e-d8df99f321a8
Using your phone as a personal hotspot
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
The password prevents others from accessing your personal hotspot without your approval.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPhone 11 Pro Max
Step 9 of 12
Step 10 of 12
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Step 11 of 12
Key in the password for the personal hotspot and establish the connection.
Step 12 of 12
