iPhone 12
iPhone 12
f-250208f9-702a-40e9-832c-3a751b38aeb5
f-2b452507-d11d-42d2-91b0-0e0bada8ffea
f-c1189e9e-2523-449f-b752-fcd0fc4b96a4
f-4f31b67e-20a0-4307-b39b-9abbd4d87d4b
f-b1fd1c2c-5892-4857-856d-ddd630019057
f-3be1f3f8-2793-416f-8075-1df7a004d3b5
Device home
Getting started
Basic functions
Calls, contacts, messaging
Using Visual Voicemail
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting. To use Visual Voicemail, you need to turn on Visual Voicemail.
Press the phone icon.
Step 1 of 18
Press Voicemail.
Press Voicemail.
Step 2 of 18
Press Voicemail.
Press Greeting.
Press Greeting.
Step 3 of 18
Press Greeting.
Press Default to select the default greeting.
Step 4 of 18
Press Custom to select a personal greeting.
Step 5 of 18
Press Record to start recording a personal greeting.
Step 6 of 18
Press Stop to stop recording.
Step 7 of 18
Press Play to play back your greeting.
Step 8 of 18
Press Save.
Press Save.
Step 9 of 18
Press Save.
Press the required message.
Step 10 of 18
Press the play icon.
Step 11 of 18
Press the speaker icon to turn the speaker on or off.
Step 12 of 18
Press the call icon to call the sender.
Step 13 of 18
Press the info icon and follow the instructions on the screen to see or save the sender information.
Step 14 of 18
Press the share icon.
Step 15 of 18
Press the required setting and follow the instructions on the screen to share or save the message.
Step 16 of 18
Press the delete icon.
Step 17 of 18
Step 18 of 18
