iPhone 12 Pro
iPhone 12 Pro
f-64acfbf7-2853-4913-8107-11ceed522caf
f-50a4ace2-c303-4f07-a8ea-af15b290ef16
f-89424b23-a68d-47c7-9f7f-cbeab3fe89ba
f-a4475e54-6cc1-4162-8aad-acf1edf98480
f-debffbc5-341f-4b69-8e66-b1be9b4b2888
f-8a454bb3-0e6b-4dc7-a2a2-2f21e86281b8
Selecting lock screen settings
You can set several lock screens on your phone and select different settings for them, such as background image, widgets and focus mode.
Press and hold anywhere on the lock screen.
Step 1 of 25
Press the add icon.
Press the add icon.
Step 2 of 25
Press the add icon.
Press the required category and follow the instructions on the screen to select the required background image.
Step 3 of 25
Depending on your choice, you can adjust the appearance of your lock screen background, e.g. by selecting colour filter and depth effect.
To customise the way the lock screen date is displayed, press the date widget and follow the instructions on the screen to find the required widget display mode.
Step 4 of 25
To customise the way the lock screen time is displayed, press the clock widget and follow the instructions on the screen to select the required settings.
Step 5 of 25
To add more lock screen widgets, press the widget field and follow the instructions on the screen to select the required widgets.
Step 6 of 25
Press Add.
Press Add.
Step 7 of 25
Press Add.
To use the same colour theme on the home screen, press Set as Wallpaper Pair.
Step 8 of 25
To use a different look for the home screen, press Customise Home Screen and follow the instructions on the screen to select the required settings.
Step 9 of 25
Press Focus.
Press Focus.
Step 10 of 25
Press Focus.
Press the required focus mode.
Step 11 of 25
You can set your phone to use a specific lock screen with a specific focus mode.
Press the close icon.
Step 12 of 25
Slide your finger upwards starting from the bottom of the screen when you're done.
Step 13 of 25
Step 14 of 25
Slide your finger right or left on the screen to select the required lock screen.
Step 15 of 25
Press the required lock screen.
Step 16 of 25
Step 17 of 25
Step 18 of 25
Press Customise and follow the instructions on the screen to customise the selected lock screen.
Step 19 of 25
Step 20 of 25
Step 21 of 25
Slide your finger upwards on the required lock screen.
Step 22 of 25
Press the delete icon.
Step 23 of 25
Press Delete This Wallpaper.
Step 24 of 25
Step 25 of 25
