iPhone 12 Pro
iPhone 12 Pro
f-64acfbf7-2853-4913-8107-11ceed522caf
f-50a4ace2-c303-4f07-a8ea-af15b290ef16
f-89424b23-a68d-47c7-9f7f-cbeab3fe89ba
f-a4475e54-6cc1-4162-8aad-acf1edf98480
f-debffbc5-341f-4b69-8e66-b1be9b4b2888
f-8a454bb3-0e6b-4dc7-a2a2-2f21e86281b8
Device home
Getting started
Basic functions
Calls, contacts, messaging
Can you use Wi-Fi?
