iPhone 12 Pro Max
iPhone 12 Pro Max
f-d742ea13-14e2-474f-8382-3e0e7fe59842
f-0910fa10-f236-401c-9ed0-e129c3bd1bcf
f-47efced3-f74f-4ffa-bf14-c5ce5d5e5250
f-578d49fd-d837-4402-b763-2525e7f72184
f-20a530fb-49ae-4254-93f6-7da2dd35b37b
f-3c8a75dc-d3bf-413d-9a75-8f1944586cba
Device home
Getting started
Basic functions
Calls, contacts, messaging
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
