iPhone 13
iPhone 13
f-2480569d-0263-4cb5-a675-9d105e80713f
f-b7bce7f0-7433-461f-93c2-b45dc3f3013f
f-3ca5983a-5043-4a0f-8975-e19df73f5e88
f-8007e571-34a2-463d-bb6a-97ab903d986e
f-88fe64a5-d033-42b2-a099-c382051a73a0
f-e2562d1f-6a13-4370-a45c-0aa0c02904bb
Device home
Getting started
Basic functions
Calls, contacts, messaging
Using Face ID
You can set your phone to use face recognition as phone lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Set Up Later.
Press Set Up Later.
Press Set Up Later.
Press Done. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
You can use your Face ID to turn off the phone lock code, allow access to apps and authorise payments.
