iPhone 13 Pro
iPhone 13 Pro
f-12224143-9af2-4a33-beda-f65181087fd7
f-a01cb92e-9384-4f0f-9949-7da940fd5b78
f-b52375a0-eca6-42f7-9dd8-56d0b2ba4f1c
f-dd76a85d-f98f-40f2-9b3d-0e6255fcce81
f-a99761f7-bb09-4f13-b5d7-55ed9ae025d2
f-625e6cdb-7361-474c-b67d-ea7fe163cf1c
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
