iPhone 14 Pro Max
iPhone 14 Pro Max
f-d56c5cc8-2a6c-4b37-8a27-9bd0f1fcc52f
f-2c7d559d-d19a-48bd-a4b1-94362d8db40f
f-9b1bcdb5-8031-4c85-96e3-f2ce67a159a8
f-08f52ffe-e04d-4146-a24b-d48183d0a01c
f-d2481693-78e0-4d38-89b8-2c909adf0208
f-2ad5327e-1948-4825-95d0-43251d27829b
f-901232d2-4559-4115-918f-66fef8697af0
Device home
Getting started
Basic functions
Calls, contacts, messaging
Using App Library
All apps on your phone are automatically organised by category in the App Library. You can set your phone to display newly downloaded apps on both the home screen and in the App Library and also adjust the number of home screen pages for a better overview of your apps.
Step 1 of 13
Press Home Screen & App Library.
Step 2 of 13
To add new downloaded apps to both the home screen and App Library, press Add to Home Screen.
Step 3 of 13
To add new downloaded apps to the App Library only, press App Library Only.
Step 4 of 13
Step 5 of 13
Slide your finger left on the screen to find the App Library.
Step 6 of 13
Press the required app.
Step 7 of 13
Press the search field and follow the instructions on the screen to search for the required app.
Step 8 of 13
Step 9 of 13
Press and hold anywhere on the home screen.
Step 10 of 13
You can adjust the number of home screen pages on your phone. Apps on deselected home screen pages are only displayed in the App Library.
Press the home screen icon.
Step 11 of 13
Press the fields below the required home screen pages to select or deselect them.
Step 12 of 13
Press Done.
Press Done.
Step 13 of 13
Press Done.
