iPhone 15 Pro
iPhone 15 Pro
f-b335600e-160c-4e52-9908-8105606980ea
f-d464d103-6546-47f5-b7b3-b078102a4cc9
f-46ae9bd8-aa51-43c0-98b0-724807c94252
f-8fe4ca3f-fdba-4ba0-88f8-f4fbc84d640b
f-7219ccab-e7b4-4ab2-a4f2-c0a3c9b38c8f
f-103ec02d-0c37-4de9-8783-be76813d6304
f-f0ff0d81-38fe-4395-8d70-fa8f32a20532
f-d68e859a-e8d5-48d3-b5e3-9f38a16d8081
Device home
Getting started
Basic functions
Calls, contacts, messaging
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
