iPad (9th Generation)
f-4e7a51cf-ff37-475a-be26-a3d890cd5bb0
f-2a8e34d9-c42b-4bb5-be09-4a38b0f9b66b
f-6039b335-de61-41b2-a699-a406fca89fe7
f-0922ebd7-1d52-4920-b438-1ecc9b067ecb
f-f2d3ea03-61c5-4329-8d18-0b64be3d3eec
f-b6ecda51-2d42-45ef-b982-d0fada882d7a
  • Contacts and messages
It's important to find out if you can use your tablet's internet connection. If you can't use your tablet's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive email messages.
Can you use your tablet's internet connection?
