iPad Air 11” (2025)
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your tablet as a personal hotspot, you need to key in the password you selected when you set up your tablet as a personal hotspot on the other device.
Check the password for the hotspot on your tablet and key in the correct password on the other device.
