iPad Air 11” (2025)
iPad Air 11” (2025)
f-64ceefad-7393-4063-b8fe-e1b19e3e755e
f-c5b8fd82-851a-4284-838e-03fad63e2a85
f-350f3843-11da-4ac8-aeb5-3c5cf298959d
f-9497562b-9f4f-47b7-8788-7b7eef9861ce
f-eb8249a9-632b-4e54-9647-b2ac4b07d5e2
f-122091ce-c2d7-4dda-a5ca-64e40cf66ae4
f-1a93c923-3d85-467d-ad7c-8f11ea018973
f-89e185bd-8213-4aad-af75-d1d5c4cf3361
  • Contacts and messages
Using widgets
You can use widgets on your tablet allowing you to get a quick overview of selected apps. You can choose between different widget sizes and organise widgets in stacks.
Slide your finger right on the screen to open the widget menu.
Step 1 of 36
Slide your finger up or down on the screen to see more widgets.
Step 2 of 36
Press and hold anywhere on the screen.
Step 3 of 36
Press the add icon.
Press the add icon.
Step 4 of 36
Press the add icon.
Press the required widget.
Step 5 of 36
If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.
Step 6 of 36
Slide your finger right or left on the screen to select the required widget size.
Step 7 of 36
Press Add Widget.
Press Add Widget.
Step 8 of 36
Press Add Widget.
Press the confirm icon.
Step 9 of 36
Step 10 of 36
A Smart Stack is an automatically created selection of widgets.
Press the add icon.
Press the add icon.
Step 11 of 36
Press the add icon.
Press Smart Stack.
Press Smart Stack.
Step 12 of 36
Press Smart Stack.
Step 13 of 36
Press Add Widget.
Press Add Widget.
Step 14 of 36
Press Add Widget.
Step 15 of 36
Press the required widget and drag it on top of another widget.
Step 16 of 36
You can manually organise the required widgets in stacks. Please note that you can only create stacks containing widgets of the same size.
Step 17 of 36
Press and hold the required Widget Stack.
Step 18 of 36
Press Edit Stack.
Press Edit Stack.
Step 19 of 36
Press Edit Stack.
Press Smart Rotate to turn the function on or off.
Step 20 of 36
Your tablet can control which widgets to display based on factors such as time, GPS position or your activity.
Press and drag the required widget to the required location.
Step 21 of 36
You can change the display order of widgets when using a Widget Stack.
Press the delete icon on the required widget to remove it from the stack.
Step 22 of 36
Step 23 of 36
Press and hold the required widget until a pop-up menu is displayed.
Step 24 of 36
Press Remove Widget.
Step 25 of 36
Press Remove.
Press Remove.
Step 26 of 36
Press Remove.
Step 27 of 36
Press and hold anywhere on the home screen.
Step 28 of 36
Press the edit icon.
Step 29 of 36
Press Add Widget.
Press Add Widget.
Step 30 of 36
Press Add Widget.
Step 31 of 36
Press Add Widget.
Press Add Widget.
Step 32 of 36
Press Add Widget.
Step 33 of 36
If you're using a Widget Stack: slide up or down on the stack to select the required widget.
Step 34 of 36
Press the required widget to open the app.
Step 35 of 36
Step 36 of 36
