iPad Air (2019)
iPad Air (2019)
f-f4fd11ea-e869-4992-af70-213cd0e6b7be
f-842f00c4-c6a6-494e-b9b5-757188cc268c
f-4cbdad83-9b03-43a7-9002-5757089eadcf
f-8b9752c7-f233-4e0a-b969-ad4c4eaaf0be
f-05ab2bd8-7270-472e-9fc5-2f2fd7b94095
f-6082e233-5b1e-4bd5-afab-e909af767a00
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPad Air (2019)
Step 9 of 12
Step 10 of 12
Step 11 of 12
Step 12 of 12
