iPad Air (2019)
It's not possible to use my tablet as a personal hotspot
If you can't use your tablet as a personal hotspot, there may be several causes of the problem.
It's important to find out if you can use your tablet's internet connection. If you can't use your tablet's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to use your tablet as a personal hotspot.
Can you use your tablet's internet connection?
