iPad Air (2020)
iPad Air (2020)
f-c6771800-16c2-438b-94db-552dbd5583f0
f-599b9298-80d0-4640-b7e6-458c9ab20006
f-b754bb35-7fe2-4961-b4e1-f885c9dfb726
f-c20f70a5-40c8-4d86-b9e8-ff2c5e728ef2
f-90d2aab1-52bb-4893-af72-7b9e263d0f5c
f-f621d4fd-fea0-48b7-a8a8-3801d21e3e16
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPad Air (2020)
Step 9 of 12
Step 10 of 12
Step 11 of 12
Step 12 of 12
