iPad mini (2021)
iPad mini (2021)
f-21df0dec-200e-4bba-a46b-b71c74752729
f-99e5f87b-ccb3-4054-83a4-976f332bf9a0
f-c9a33f09-86f1-4651-a1c0-c13b96678812
f-6cf379bc-8b59-4421-b34a-b79c7a3e7f3e
f-32ca2d78-62fd-4e7d-8b25-c5d1ddb6d5e8
f-0240c1e7-676d-4ac3-bf36-5b39617a8875
  • Contacts and messages
Device home
Getting started
Basic functions
It's important to find out if you can use your tablet's internet connection. If you can't use your tablet's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive email messages.
Can you use your tablet's internet connection?
