iPad Pro 11 (2021)
iPad Pro 11 (2021)
f-3ac0507f-95da-4693-8705-b3a89fc7161c
f-39f41b3f-ffe8-437e-8d41-6658048b7191
f-51db3d3d-0424-4ae0-b312-3cc130cae418
f-f333274b-69f7-4915-9cac-9c2b5e95a6d3
f-8ff3b87e-c3f5-4d2d-b154-b8d8c4a51513
f-74657c34-490e-4d93-b360-34777db6966a
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPad Pro 11 (2021)
Step 9 of 12
Step 10 of 12
Step 11 of 12
Step 12 of 12
