iPad Pro 11 (2021)
iPad Pro 11 (2021)
f-3ac0507f-95da-4693-8705-b3a89fc7161c
f-39f41b3f-ffe8-437e-8d41-6658048b7191
f-51db3d3d-0424-4ae0-b312-3cc130cae418
f-f333274b-69f7-4915-9cac-9c2b5e95a6d3
f-8ff3b87e-c3f5-4d2d-b154-b8d8c4a51513
f-74657c34-490e-4d93-b360-34777db6966a
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your tablet as a personal hotspot, you need to key in the password you selected when you set up your tablet as a personal hotspot on the other device.
Check the password for the hotspot on your tablet and key in the correct password on the other device.
