iPad Pro 11" (2024)
iPad Pro 11" (2024)
f-d19e4cc4-d4da-49cd-bfd9-6b9d3127fbbe
f-f806b988-ed04-4fe4-8faa-06d4eae2875e
f-a196643d-7ce9-45ea-8d1b-80a7848cab76
f-2e721fcf-6d91-47c3-bc94-81d24fa1d539
f-679c9ccf-600e-43e3-a4ec-c4d0fd9579e2
f-e7fdea48-0619-4097-bfc9-3aac9b9450ca
f-1bcc0678-8bd6-40c5-9337-2517695cecfd
f-1460de49-5c65-4333-922f-f1421cf679c7
  • Contacts and messages
Selecting network mode
There may be different network modes available depending on where you are. The network mode influences the data speeds your tablet can achieve.
Press Mobile Data.
Press Mobile Data.
Press Mobile Data.
Press Mobile Data Options.
Press Data.
Press Data.
Press Data.
To turn on automatic switch between 5G and 4G, press 5G Auto.
Your tablet will only use 5G for functions that do not have a significant impact on the battery consumption. Your tablet automatically switches between 4G and 5G depending on whether you have 5G network coverage or not.
To turn on use of 5G primarily, press 5G On.
Your tablet will primarily use 5G even though it may cause an increase in battery consumption. Your tablet automatically switches between 4G and 5G depending on whether you have 5G network coverage or not.
To use 4G only, press 4G.
