iPad Pro 11 (2025)
iPad Pro 11 (2025)
f-ddaca463-bdc2-43d3-b165-868e3098f154
f-144f9613-607b-40ca-bbca-8390ebb5bd28
f-ae84e403-a911-4879-85d7-03b1e0a15c7a
f-2138d661-922d-47ac-8ac4-c0c66fe139de
f-b2c4fe9c-8481-473f-83ea-4e0861f9bf64
f-63d35b5d-865b-46d9-8a8b-ca16457b7747
  • Contacts and messages
Using Face ID
You can set your tablet to use face recognition as lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Continue.
Press Continue.
Press Continue.
Press Done. If you haven't previously selected a lock code, key in a code of your own choice twice.
You can use your Face ID to turn off the lock code, allow access to apps and authorise payments.
