iPad Pro 11 (2025)
Using widgets
You can use widgets on your tablet allowing you to get a quick overview of selected apps. You can choose between different widget sizes and organise widgets in stacks.
Slide your finger right on the screen to open the widget menu.
Slide your finger up or down on the screen to see more widgets.
Press and hold anywhere on the screen.
Press the add icon.
Press the required widget.
If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.
Slide your finger right or left on the screen to select the required widget size.
Press Add Widget.
Press the confirm icon.
Press the add icon.
Press Smart Stack.
Press Add Widget.
Press the required widget and drag it on top of another widget.
Press and hold the required Widget Stack.
Press Edit Stack.
Press Smart Rotate to turn the function on or off.
Press and drag the required widget to the required location.
Press the delete icon on the required widget to remove it from the stack.
Press and hold the required widget until a pop-up menu is displayed.
Press Remove Widget.
Press Remove.
Press and hold anywhere on the home screen.
Press the edit icon.
Press Add Widget.
Press Add Widget.
½If you're using a Widget Stack: slide up or down on the stack to select the required widget.
Press the required widget to open the app.
