iPad Pro 11" (4th Gen)
f-ef49fa9b-d454-4009-ac92-ce2fc306dd3c
f-ffd87bb1-17a4-40f7-9deb-4fb3c905150d
f-54eef959-b637-4a2b-ab1a-86b5fb31f83c
f-9b9d5254-4e3b-4a45-bf13-aa411508fbbc
f-cab914fb-1836-4425-ab1e-127394220f57
f-5d213c0f-5ffe-4448-abf1-ef8e38304213
  • Contacts and messages
Using Face ID
You can set your tablet to use face recognition as lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Done. If you haven't previously selected a lock code, key in a code of your own choice twice.
You can use your Face ID to turn off the lock code, allow access to apps and authorise payments.
