iPad Pro 11" (4th Gen)
Solution 1 of 3: Your tablet hasn't been correctly set up for POP3 email
You can set up your tablet to send and receive email messages from your email accounts. Using POP3, your email messages are retrieved to your tablet and at the same time they are deleted from the server. You're then not able to access your email messages from other devices. To set up your tablet for POP3 email, you need to set up your tablet for internet.
Press Mail.
Press Accounts.
Press Add Account.
Press Other.
Press Add Mail Account.
Press Name and key in the required sender name.
Press Email and key in your email address.
Press Description and key in the required name.
Press Next.
If this screen is displayed, you email account has been recognised and set up automatically. Follow the instructions on the screen to key in more information and finish setting up your tablet.
Press POP.
Press Host Name and key in the name of your email provider's incoming server.
Press Username and key in the username for your email account.
Press Host Name and key in the name of your email provider's outgoing server.
Press Save. Your email account has now been set up. To select more settings for incoming and outgoing server, proceed with the following steps.
Press the name of the email account you've just set up.
Press SMTP.
Press the field below "PRIMARY SERVER".
Press the indicator next to "Use SSL" to turn off the function.
Press Authentication.
Press Password.
Press arrow left.
Press Server Port and key in 25.
Press Done.
Press arrow left.
Press Advanced.
Press Password.
Press arrow left.
Press Server Port and key in 110.
Press arrow left.
Press Done.
Press Fetch New Data.
Press the indicator next to "Push" to turn the function on or off.
If you turn off the function, press the required setting.
Press the required email account and follow the instructions on the screen to select settings for the specific account.
