iPad Pro 12.9 (2018)
Using Face ID
You can set your tablet to use face recognition as lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Continue.
Press Done. If you haven't previously selected a lock code, key in a code of your own choice twice.
Press the indicator next to "iPad Unlock" to turn the function on or off.
Press the indicator next to "iTunes & App Store" to turn the function on or off.
