iPad Pro 12.9 (2018)
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Press Personal Hotspot.
Press the indicator next to "Personal Hotspot" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Press Wi-Fi Password and key in the required password.
Press Done.
