iPad Pro 12.9 (2020)
f-fbec6791-c624-4144-8e65-dadbb8359870
f-2843e4af-f5fc-4ef7-8332-6ea6e99ea68a
f-0e2bc42a-e96b-44f2-bba3-fcf5a6f841df
f-01fff428-90b6-4003-8e35-b78ed4d138ba
f-ab411f65-9f35-4627-ab47-8bafff0a8118
f-248ca63e-3de5-4ab2-b293-923af459f598
  • Contacts and messages
Using Face ID
You can set your tablet to use face recognition as lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Done. If you haven't previously selected a lock code, key in a code of your own choice twice.
Press the indicator next to "iPad Unlock" to turn the function on or off.
If you turn on the function, you can use your Face ID to turn off the lock code.
Press the indicator next to "iTunes & App Store" to turn the function on or off.
If you turn on the function, you can use your Face ID to authorise iTunes and App Store purchases.
