iPad Pro 12.9 (2020)
f-fbec6791-c624-4144-8e65-dadbb8359870
f-2843e4af-f5fc-4ef7-8332-6ea6e99ea68a
f-0e2bc42a-e96b-44f2-bba3-fcf5a6f841df
f-01fff428-90b6-4003-8e35-b78ed4d138ba
f-ab411f65-9f35-4627-ab47-8bafff0a8118
f-248ca63e-3de5-4ab2-b293-923af459f598
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 2 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPad Pro 12.9 (2020)
Step 9 of 12
Step 10 of 12
Step 11 of 12
Step 12 of 12
