iPad Pro 12.9 (2021)
f-f42fd9fb-8495-4a2a-84e4-0321df22ac3f
f-70551086-3439-4d97-995f-e166209968c1
f-16b06e48-4091-4bae-b936-8d1f7457dd42
f-76b96215-c698-4e9d-a7a4-506c37a48512
f-681da282-a8f0-4651-bd8c-3c4fb8ee31e6
f-c4dde050-f6d9-48bd-81cb-af6f3f6e4412
  • Contacts and messages
It's not possible to use my tablet as a personal hotspot
Solution 1 of 2: Personal hotspot isn't used correctly
When you use your tablet as a personal hotspot, you can share your tablet's internet connection with other devices via Wi-Fi. To use your tablet as a personal hotspot, you need to set up your tablet for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Press Done.
Step 4 of 12
Press Done.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPad Pro 12.9 (2021)
Step 9 of 12
Step 10 of 12
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Step 11 of 12
Key in the password for the personal hotspot and establish the connection.
Step 12 of 12
