iPad Pro 12.9" (6th Gen)
Using Face ID
You can set your tablet to use face recognition as lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Continue.
Press Done. If you haven't previously selected a lock code, key in a code of your own choice twice.
