iPad Pro 12.9" (6th Gen)
f-d77d8bac-40f4-4d55-965a-1facf79d315f
f-5e51a872-9216-40a6-941f-bce2a41f21d5
f-3af40175-2de4-41c2-857c-f179d9f0db58
f-6788974e-8d4d-43df-bae1-598c27602d80
f-c5980d8d-0649-4c25-89cb-7abbfa5729d9
f-87e7b2a6-9353-4b99-a096-86e2b1f48c7f
f-e7110d82-7491-4e84-b0ad-49c05a5627f2
f-be321130-1f2d-4c34-94ce-4a21788a70f5
  • Contacts and messages
Using widgets
You can use widgets on your tablet allowing you to get a quick overview of selected apps. You can choose between different widget sizes and organise widgets in stacks.
Slide your finger right on the screen.
Step 1 of 30
Press Edit.
Press Edit.
Step 2 of 30
Press Edit.
Press the add icon.
Press the add icon.
Step 3 of 30
Press the add icon.
Press the required widget.
Step 4 of 30
If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.
Step 5 of 30
Slide your finger right or left on the screen to select the required widget size.
Step 6 of 30
Press Add Widget.
Press Add Widget.
Step 7 of 30
Press Add Widget.
Press Done.
Press Done.
Step 8 of 30
Press Done.
Press Edit.
Press Edit.
Step 9 of 30
Press Edit.
A Smart Stack is an automatically created selection of widgets.
Press the add icon.
Press the add icon.
Step 10 of 30
Press the add icon.
Press Smart Stack.
Press Smart Stack.
Step 11 of 30
Press Smart Stack.
Step 12 of 30
Press Add Widget.
Press Add Widget.
Step 13 of 30
Press Add Widget.
Press Done.
Press Done.
Step 14 of 30
Press Done.
Press the required widget and drag it on top of another widget.
Step 15 of 30
You can manually organise the required widgets in stacks. Please note that you can only create stacks containing widgets of the same size.
Press Done.
Press Done.
Step 16 of 30
Press Done.
Press and hold the required Widget Stack.
Step 17 of 30
Press Edit Stack.
Press Edit Stack.
Step 18 of 30
Press Edit Stack.
Press Smart Rotate to turn the function on or off.
Step 19 of 30
Your tablet can control which widgets to display based on factors such as time, GPS position or your activity.
Press and drag the required widget to the required location.
Step 20 of 30
You can change the display order of widgets when using a Widget Stack.
Press the delete icon on the required widget to remove it from the stack.
Step 21 of 30
Press Done.
Press Done.
Step 22 of 30
Press Done.
Press and hold the required widget until a pop-up menu is displayed.
Step 23 of 30
Step 24 of 30
Press Remove.
Press Remove.
Step 25 of 30
Press Remove.
Press and hold the required widget. Drag the selected widget to the required position on the home screen.
Step 26 of 30
Press Done.
Press Done.
Step 27 of 30
Press Done.
If you're using a Widget Stack: slide up or down on the stack to select the required widget.
Step 28 of 30
Press the required widget to open the app.
Step 29 of 30
Step 30 of 30
