iPhone 11 Pro
It's not possible to use my phone as a personal hotspot
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a personal hotspot, you need to key in the password you selected when you set up your phone as a personal hotspot on the other device.
Check the password for the hotspot on your phone and key in the correct password on the other device.
x
Get information on
Or select
Another device
