iPhone 11 Pro
![f-d58d818c-46b3-4cdd-aacf-cb56c2e5c3e9](http://wmstatic.global.ssl.fastly.net/ml/020724-f-d58d818c-46b3-4cdd-aacf-cb56c2e5c3e9.png?width=140&height=200)
![f-df7b0086-ec80-45f9-9dea-129aa40c8c79](http://wmstatic.global.ssl.fastly.net/ml/020724-f-df7b0086-ec80-45f9-9dea-129aa40c8c79.png?width=140&height=200)
![f-c1e36cc4-b186-4ca5-947c-fed1d64a3e28](http://wmstatic.global.ssl.fastly.net/ml/020724-f-c1e36cc4-b186-4ca5-947c-fed1d64a3e28.png?width=140&height=200)
![f-609c85e1-4fc2-445d-8907-e59ce072dcd0](http://wmstatic.global.ssl.fastly.net/ml/020724-f-609c85e1-4fc2-445d-8907-e59ce072dcd0.png?width=140&height=200)
![f-fb87405b-7a33-4ab5-a030-09ee613266b7](http://wmstatic.global.ssl.fastly.net/ml/020724-f-fb87405b-7a33-4ab5-a030-09ee613266b7.png?width=140&height=200)
![f-eb0f7e31-740b-4780-aa33-266686532943](http://wmstatic.global.ssl.fastly.net/ml/020724-f-eb0f7e31-740b-4780-aa33-266686532943.png?width=140&height=200)
Using widgets
You can use widgets on your phone allowing you to get a quick overview of selected apps. You can choose between different widget sizes, organise widgets in stacks and place them on the home screen.
![Slide your finger right on the screen. Slide your finger right on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-768466fe-c6a5-437d-b78f-e6a8bc65ebce.png?width=234&height=506)
![Slide your finger right on the screen. Slide your finger right on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-768466fe-c6a5-437d-b78f-e6a8bc65ebce.png?width=346&height=752)
![Slide your finger upwards on the screen. Slide your finger upwards on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=234&height=506)
![Slide your finger upwards on the screen. Slide your finger upwards on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=346&height=752)
![Press Edit. Press Edit.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-6d33e645-016d-4ebb-9037-9e7be5edbe47.png?width=234&height=506)
![Press Edit. Press Edit.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-6d33e645-016d-4ebb-9037-9e7be5edbe47.png?width=346&height=752)
Press Edit.
![Press the add icon. Press the add icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-594db1a2-e462-4b59-a3bd-5fab226af1d3.png?width=234&height=506)
![Press the add icon. Press the add icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-594db1a2-e462-4b59-a3bd-5fab226af1d3.png?width=346&height=752)
Press the add icon.
![Press the required widget. Press the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7922ad30-f83a-4aa9-860b-42e906d1a1c5.png?width=234&height=506)
![Press the required widget. Press the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7922ad30-f83a-4aa9-860b-42e906d1a1c5.png?width=346&height=752)
![If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget. If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7922ad30-f83a-4aa9-860b-42e906d1a1c5.png?width=234&height=506)
![If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget. If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7922ad30-f83a-4aa9-860b-42e906d1a1c5.png?width=346&height=752)
![Slide your finger right or left on the screen to select the required widget size. Slide your finger right or left on the screen to select the required widget size.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-12796ec0-dabe-4bdb-b70c-a9d9830852fe.png?width=234&height=506)
![Slide your finger right or left on the screen to select the required widget size. Slide your finger right or left on the screen to select the required widget size.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-12796ec0-dabe-4bdb-b70c-a9d9830852fe.png?width=346&height=752)
![Press Add Widget. Press Add Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-12796ec0-dabe-4bdb-b70c-a9d9830852fe.png?width=234&height=506)
![Press Add Widget. Press Add Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-12796ec0-dabe-4bdb-b70c-a9d9830852fe.png?width=346&height=752)
Press Add Widget.
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9fed293a-5617-4a69-adca-352c50e939d8.png?width=234&height=506)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9fed293a-5617-4a69-adca-352c50e939d8.png?width=346&height=752)
Press Done.
![Press Edit. Press Edit.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-880fb60f-a7cc-4d6b-b33f-42dde392a869.png?width=234&height=506)
![Press Edit. Press Edit.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-880fb60f-a7cc-4d6b-b33f-42dde392a869.png?width=346&height=752)
Press Edit.
Press the add icon.
![Press Smart Stack. Press Smart Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b3c70dc6-fbca-4f0b-a936-4a23f57b2771.png?width=234&height=506)
![Press Smart Stack. Press Smart Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b3c70dc6-fbca-4f0b-a936-4a23f57b2771.png?width=346&height=752)
Press Smart Stack.
![Slide your finger right or left on the screen to select the required widget size. Slide your finger right or left on the screen to select the required widget size.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-84fdc808-ae4b-49a1-870b-984985ced083.png?width=234&height=506)
![Slide your finger right or left on the screen to select the required widget size. Slide your finger right or left on the screen to select the required widget size.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-84fdc808-ae4b-49a1-870b-984985ced083.png?width=346&height=752)
![Press Add Widget. Press Add Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-84fdc808-ae4b-49a1-870b-984985ced083.png?width=234&height=506)
![Press Add Widget. Press Add Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-84fdc808-ae4b-49a1-870b-984985ced083.png?width=346&height=752)
Press Add Widget.
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-26ed27ae-8eca-4387-b61d-0f27d5075b43.png?width=234&height=506)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-26ed27ae-8eca-4387-b61d-0f27d5075b43.png?width=346&height=752)
Press Done.
![Press the required widget and drag it on top of another widget. Press the required widget and drag it on top of another widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=234&height=506)
![Press the required widget and drag it on top of another widget. Press the required widget and drag it on top of another widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=346&height=752)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-33f41899-3ebf-4f84-9148-017b77602665.png?width=234&height=506)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-33f41899-3ebf-4f84-9148-017b77602665.png?width=346&height=752)
Press Done.
![Press and hold the required Widget Stack. Press and hold the required Widget Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-0f85955b-edac-4603-9194-12b57072c07a.png?width=234&height=506)
![Press and hold the required Widget Stack. Press and hold the required Widget Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-0f85955b-edac-4603-9194-12b57072c07a.png?width=346&height=752)
![Press Edit Stack. Press Edit Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-03d90043-f6eb-4737-806f-305933dce2ed.png?width=234&height=506)
![Press Edit Stack. Press Edit Stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-03d90043-f6eb-4737-806f-305933dce2ed.png?width=346&height=752)
Press Edit Stack.
![Press Smart Rotate to turn the function on or off. Press Smart Rotate to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=234&height=506)
![Press Smart Rotate to turn the function on or off. Press Smart Rotate to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=346&height=752)
![Press and drag the required widget to the required location. Press and drag the required widget to the required location.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=234&height=506)
![Press and drag the required widget to the required location. Press and drag the required widget to the required location.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=346&height=752)
![Press the delete icon on the required widget to remove it from the stack. Press the delete icon on the required widget to remove it from the stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=234&height=506)
![Press the delete icon on the required widget to remove it from the stack. Press the delete icon on the required widget to remove it from the stack.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=346&height=752)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=234&height=506)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4a806b4b-1e1c-4baf-b043-d72295ae6095.png?width=346&height=752)
Press Done.
![Press and hold the required widget until a pop-up menu is displayed. Press and hold the required widget until a pop-up menu is displayed.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-880fb60f-a7cc-4d6b-b33f-42dde392a869.png?width=234&height=506)
![Press and hold the required widget until a pop-up menu is displayed. Press and hold the required widget until a pop-up menu is displayed.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-880fb60f-a7cc-4d6b-b33f-42dde392a869.png?width=346&height=752)
![Press Remove Widget. Press Remove Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-96315c20-8d31-4c96-b8ba-d9835ba49285.png?width=234&height=506)
![Press Remove Widget. Press Remove Widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-96315c20-8d31-4c96-b8ba-d9835ba49285.png?width=346&height=752)
![Press Remove. Press Remove.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f8cd04fc-d049-441d-9a1f-ac48a9d2ffba.png?width=234&height=506)
![Press Remove. Press Remove.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f8cd04fc-d049-441d-9a1f-ac48a9d2ffba.png?width=346&height=752)
Press Remove.
![Press and hold the required widget. Drag the selected widget to the required position on the home screen. Press and hold the required widget. Drag the selected widget to the required position on the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=234&height=506)
![Press and hold the required widget. Drag the selected widget to the required position on the home screen. Press and hold the required widget. Drag the selected widget to the required position on the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-50d07568-2844-48fd-af5b-d05e4f1c9520.png?width=346&height=752)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b65d1fd7-736b-4563-8c05-d07ba294f900.png?width=234&height=506)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b65d1fd7-736b-4563-8c05-d07ba294f900.png?width=346&height=752)
Press Done.
![If you're using a Widget Stack: slide up or down on the stack to select the required widget. If you're using a Widget Stack: slide up or down on the stack to select the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74a0a8e3-78b6-4427-b04c-b65e74b36ad9.png?width=234&height=506)
![If you're using a Widget Stack: slide up or down on the stack to select the required widget. If you're using a Widget Stack: slide up or down on the stack to select the required widget.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74a0a8e3-78b6-4427-b04c-b65e74b36ad9.png?width=346&height=752)
![Press the required widget to open the app. Press the required widget to open the app.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74a0a8e3-78b6-4427-b04c-b65e74b36ad9.png?width=234&height=506)
![Press the required widget to open the app. Press the required widget to open the app.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74a0a8e3-78b6-4427-b04c-b65e74b36ad9.png?width=346&height=752)
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9af010b0-122c-4a53-a8e4-6f8094fe6197.png?width=234&height=506)
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9af010b0-122c-4a53-a8e4-6f8094fe6197.png?width=346&height=752)
