iPhone 11 Pro Max
Setting up your phone for POP3 email
You can set up your phone to send and receive email messages from your email accounts. Using POP3, your email messages are retrieved to your phone and at the same time they are deleted from the server. You're then not able to access your email messages from other devices. To set up your phone for POP3 email, you need to set up your phone for internet.
Step 1 of 41
Press Passwords & Accounts.
Step 2 of 41
Press Add Account.
Step 3 of 41
Press Add Account.
Press Other.
Step 4 of 41
Press Other.
If the name of your email provider is on the list, press this instead.
Press Add Mail Account.
Step 5 of 41
Press Name and key in the required sender name.
Step 6 of 41
Press Email and key in your email address.
Step 7 of 41
Step 8 of 41
Press Description and key in the required name.
Step 9 of 41
Press Next.
Step 10 of 41
Press Next.
Step 11 of 41
Press POP.
Step 12 of 41
Press POP.
Press Host Name and key in the name of your email provider's incoming server.
Step 13 of 41
Press Username and key in the username for your email account.
Step 14 of 41
Press Host Name and key in the name of your email provider's outgoing server.
Step 15 of 41
Step 16 of 41
Step 17 of 41
Press Save. Your email account has now been set up. To select more settings for incoming and outgoing server, proceed with the following steps.
Step 18 of 41
Press the name of the email account you've just set up.
Step 19 of 41
Press SMTP.
Step 20 of 41
Press SMTP.
Press the field below
Step 21 of 41
Press the field below "PRIMARY SERVER".
Step 22 of 41
Press the indicator next to "Use SSL" to turn off the function.
Press Authentication.
Step 23 of 41
Press Password.
Step 24 of 41
Press Password.
Press arrow left.
Step 25 of 41
Press arrow left.
Press Server Port and key in 25.
25
Step 26 of 41
Press Done.
Step 27 of 41
Press Done.
Press arrow left.
Step 28 of 41
Press arrow left.
Press Advanced.
Step 29 of 41
Press Advanced.
Step 30 of 41
Step 31 of 41
Press Password.
Step 32 of 41
Press Password.
Press arrow left.
Step 33 of 41
Press arrow left.
Press Server Port and key in 110.
110
Step 34 of 41
Press arrow left.
Step 35 of 41
Press arrow left.
Press Done.
Step 36 of 41
Press Done.
Press Fetch New Data.
Step 37 of 41
Step 38 of 41
Press the indicator next to "Push" to turn the function on or off.
If you turn off the function, press the required setting.
Step 39 of 41
Press the required email account and follow the instructions on the screen to select settings for the specific account.
Step 40 of 41
Step 41 of 41
x
Get information on
Or select
Another device
