iPhone 11 Pro Max
Writing and sending an iMessage
You can send iMessages to phone numbers or email addresses if the recipient has a device which supports iMessage. To write and send iMessages, you need to set up your phone for iMessaging.
Press the message icon.
Step 1 of 9
Press the new message icon.
Step 2 of 9
Press To: and key in the first letters of the recipient's name.
Step 3 of 9
Press the required contact.
Step 4 of 9
If the recipient can receive iMessages, iMessage is displayed in the text input field.
Step 5 of 9
Press the text input field and key in the required text.
Step 6 of 9
Press the send icon.
Step 7 of 9
You can also send pictures, video clips, audio files and different effects in your iMessage. Follow the instructions on the screen to send your iMessage with the required content.
Step 8 of 9
Step 9 of 9
